New Pull Orientation Shown Wrong
Hi All,
It's been awhile since I've added a new pull to my Library v49_1. I have everything working except for when I draw my Elevation. The pull is showing vertically on my trash pull-out, when it should be horizontal.
I switch to another pull that was added and it draws correctly. The new pull was taken from the other one and updated for the new size. So, the hardware flatshots are oriented the same...yet, can not get the elevation to draw correctly, even rotated 90deg's and showed the same after Redraw & Pull change.. The 3D & vertical sections draw correctly.
Even went back to notes from Tim S. handout  form TechCon & the Knowledge base article. Reloaded the Project and room with same results. Any ideas? I added this to an existing Project after developing the pull in another. Than tested in a New Project and New Room with correct orientation in my Elevation and Vertical Sections.
Any ideas appreciated!
