Is there a non-associative machine token for dadoes? The only thing I can see that works for adding dadoes is a pline. Even if I go into draw part and use the 2d machining tools like the rectangular pocket, the token generated is a pline.
Basically, I'm trying to add some dadoes that are parametric to the cabinet they're in, and the correlating parts are not 4 sided, so I can't use associative tokens. I manually drew the first one and edited the vector list to hold the parametric values I want to use, but it's getting messy pretty fast.
