OEM importing blocks into the tools palette?
So I imported the clients tool palette into a new tool palette with their name after i put the files into the correct location. All good. I go to try and drag into my drawing and it doesn't work. So I look at the properties and the "source file" is in a different location than I want it to be. How do I change all of them at once or is there a better way to import them than 1 by 1?
Are You Ready to Streamline the Way You Learn?
