Offset dowel holes for fixed shelves
Currently, I am running MV 2023 Library 50.7. I cannot find the setting to turn off the dowel offset on finished and unfinished ends when it comes to fixed shelves. It shows this code in the machining tokens for fixed shelves "=Dim_To_First_Dowel_Hole+Offset_Dowels_On_Left". I do not want the offset to happen at all. I looked in global construction and global machining. Any help? Thank you.
