Option to Change Configuration Units Outside of Registry
We work with many client's configurations, and often need to switch between SQL CE configurations that are both metric and imperial. Currently, the only way that I am aware of to change the Units (after initial install of MV) is through the registry.
It would be great if this setting could be changed in the MVOptions interface somewhere to make it easier, and visible to users.
