Part Block & Virtual Machine Base - Wood Hacks S1:E10
Hi Friends,
In this episode of Wood Hacks, you'll learn all about the part block and virtual machine base that is used to help determine part location, orientation, and machining origins.
Learn to identify exactly how the machining instructions for parts are being calculated, so the next time you need to modify your cabinet parts or make new products, you'll be a pro...
