I have a problem with the pilot hole drilling on my Diagonal Corner Cabinets. The problem is on the Upper and Base Diagonal Corner Cabinets. The formula for the pilot holes is not moving the holes back from the corner of the top and bottom to contact the cabinet ends. In the captures, the formula result is 32, 250 but should be 328, 546 after adding the PieCut Offset of 296. I am reasonably sure the issue is in the formulas but I am unable to solve the problem.
