Placing a tall cabinet doesn't render the parts correctly - Am I missing a setting?
Hi,
My drafters brought this to my attention yesterday.  When I place a cabinet and make it tall.  The door should have a mid rail and two center panels.  However it renders without the mid rail and just one large center panel (see below)
The problem is if you redraw the cabinet, it will draw properly, and if you check part properties/door subassembly, the door has 2 panels and a mid rail.
Is there a certain reason they are not being rendered  the first time after placing the cabinet?
Other notes, this was happening on an old build
MV 2025 25.2.213.641
And I just installed the newest build
MV 2025 26.1.0723.641
Any help or maybe its a BricsCad setting we are not aware of.
Thanks,
-James
