PLINE on different face?
Anytime I use the PLINE machining token 1 through 6 in cuts into the top or bottom face, but I'm trying to cut a pocket into the bottom of my rail from one end to 1/2" before the other end. Same with cutting a dado, I've been using the profile edge machine token with a square as my dwg. because that's the only way I can get to cut a dado on the side of my rail instead of the faces.
