PLINE Token unique feed rates
Is anyone using the third column in the PLINE token to apply a feed speed per vector and override the toolfile rates?
I've used this feature a long time ago in V67 (to slow down the feed of a route doing an corner clearance cut on the exit side of passage door rabbets), but lately I haven't been able to get the unique feed speeds to show up in the G code. They doesn't seem to transfer form the product spreadsheet to the work-order.
Thanks for any help or guidance.
