PLINE Z Values
Does anyone have any experience with creating a PLINE token that uses negative Z values?
If i use these coordinates:
100;100;1|115;150;1|130;100;1|130;100;-5|102.5;120;-5|102.5;120;1|127.5;120;1
i get this on my drawing:
I would expect it to lift and not mark the part on the transition.
Also it only gives the cutter profile to the segment after the transition.
When i process the part, it removes that have the same X and Y values (but a different Z value) and i get gcode that would look like this:
100;100;1|115;150;1|130;100;-5|102.5;120;1|127.5;120;1
