"Primary Tool File"
What would cause this message while analyzing?
I am attempting to add "Vertical Drilling" to the "Studs" for Keku Push-In Fittings.
Is there a step in the "Tool File" that I need to provide?
What is causing the Ø of the "Stud Bore to be Ø0.1575 and not the Ø0.15625 that the "Geometry" reflects?
I did change the #3 & #4 Tool to be Ø0.15625 and the panel holes now show up as Ø0.1563 and the bore is the depth I want.
