Hello there
A bit new with this, it may be a easy question but i recently formatted a working station and reinstalled MV and ran into a few trouble setting things up. Solved most trouble searching this forum but this one cant find anything.
When i create a Work Order, normally it will open it in the processing station right away (or at least ask) but not anymore. It create it then go back to the drawing and i have to go in "Edit Existing Work Order".
Am i missing a check box somewhere so it will always open the processing station? I set the options the same way the others MV are set.
Thank you
