Prompts Save Initial State
Many prompts START as formulas, but will be overwritten with either modified formula's or hard coded values as you adjust the product to what you need in a particular instance.  But its not uncommon to realize you changed something that you should not have changed.  And the only way to get the value back would be to place a new instance of the product and pull the formula from that.  It would be nice if when a product is saved to the library, that its initial prompts are saved somewhere...like over in those columns IW+.  Which would give you the ability to revert changes to any prompt in a product.  Would also allow some safety checks similar to the checks done when you save a subassembly.  "This value WAS a formula when the product was brought in, but its a hard coded value now" or the formula has been changed.
