I am in the process of testing out the Foundation library to hopefully change over from the component library soon. I am noticing that in the Globals of the foundation library there is a setting called "Drawer Handle Distance From Top". I have this set to our standard 76mm. In the component library we had this global set to the same value. The issue I am having is that in the component library it would set the pull 76mm down from the top edge of a drawer front as it should until it got to a front that was under 152mm in height, then it would center it.
I would like the foundation library to do the same, however I can only get it to locate pulls 76mm down (no matter what the drawer front height) or center the pull on all drawer front no matter the height.
See attached photo. You will see that the component library uses a formula for the distance. Where foundation has a simple value.
Do any one else hove there pulls set this way? is there a fix to meet my needs. Thanks
