Hello,
I am new to the world of Microvellum and cabinetry and wanted to see if anybody out there could point me in the correct direction on how to handle a change I need to make for our library in relation to pullout/Inner drawers. Currently when we use a pullout/inner drawer we add a 1" spacer which I am currently able to do in the latest foundation library. The issue I have run into is the spacer we use is different then the spacer that is built in the system. We typically use a Hettich spacer block(See Attached Image).
If you have any suggestions on how I could create this piece as hardware and how to add the machine tokens so it will machine on the sides of cabinets?
I appreciate any suggestions.
thanks,
Eric Sorenson
