Radius corners getting a square boarder route, then the radius, in the nest
I am having an issue where parts analyzed with SMA is not including the radius in the boarder route in the nest.  The nest will do the radius machining first, then there will be a boarder route, routing the perimeter of the part but not including the radius corner on those parts.
I updated to the 22.1.525.641 build, but this has been a problem in previous builds as well.
