Ramp in, Ramp out
Would it be possible to alter the ramp in, ramp out feature?
At present when geometry is added to a nest, which happens quite frequently and a toolpath is applied you have to change to route editing tools and add a lead in and then go back and add the lead out.
Could this have not been a setting?  I know that some apps have it to where you can set the default lead in and lead out distance based on the diameter of the tool or select a custom amount.  Then when you apply tooling you can choose a routine that has lead ins and outs and apply. A whole lot less switching back and forth and many times quicker.  Just sayin' can this be added to the list?
