Referencing the Product Angle In the spreadsheet
Does anyone know how to reference the Product Angle in a formula within that product?
I'm setting up Drawing Tokens in a bunch of our subassemblies. Particularly on plan section tokens for a carcass base i'm hitting a wall getting the hatch angle to draw correctly.
I presumed i could set the hatch angles assuming a "0 deg" product angle and everything would be relative. It's working like that drawing the rectangles for the back and sides, but the hatches are being drawn 90 degrees off on products rotated 90 or 270.
I figured if i can reference the product's angle, then i can use a formula to change the hatch angle based on the Product Angle.
I'd hoped there was some old system prompt called ProductAngle, but no such luck, for that name anyway.
