Remove Barcode Asterisks
Hi,
Production is trying to use our Labels to Scan a Barcode for our Drilltek machine.  We're using Code 3 of 9 font, with barcode format set to FileName (No Extension).  Our Tech out there is saying its scanning with the correct name, however it wont select the file because it has Asterisks at the start and end of the name.  I.E. *A3007VMW* which we need to just be A3007VMW.
Is this a Microvellum setting or something we need to update on our CNC Machines?  I think I've done about every test I can do on my end and not sure where to go from here.  Let me know if there is more info required and I will try to get it.
Thanks,
-James
