When I place a Die wall without skins (Studs only) With "Die wall w/skins" I'm getting a bad product.
Itt's removing the plates on top and bottom and showing only the inside skin. for some reason the origin seems to be an issue. This is the result (attached) Could not attached the pdf. Am I doing something wrong here?
The Product with no skins works fine and for all intents and purposes I have learned o get around this but just wondering if this is an issue for others ?
