Anyone aware of an issue/bug that'd cause a report to not populate correctly in the Report Designer?
The report works 100% fine when you preview/print it from the Work Order processing screen. It's only Report Designer where all fields are showing up empty.
When I go to the Data Sources and view data there, the databases aren't correct. Only the projects table has data, all other tables including the products table is completely empty. I tried resetting the data source by going into Edit Data Source and setting the database type as Microvellum Work Order, but that doesn't seem to do anything.
I've tried selecting other work orders and different reports. It's doing the same thing no matter what WO is selected, but it seems that it's only some reports that are effected.
Like I mentioned, it's still printing off correctly from the actual work order processing screen, but this is making editing these reports a pain.
