Hello,
We would like to use a radius point bit to create a bead board but are having issues actually drawing the radius. Instead, it appears as a square cut.
The router bit drawing is a closed polyline located at the 0,0,0 coordinates at the center tip in the router bits folder.
We have associated the router bit drawing to the matching tool in the tool file
The tool drawing name is: 1_4_Radius_Point
Would anyone know what is happening or how to fix this? Thank you.
