Router Set Up Sheet?
We have 2 routers with a different number of spindles.  Therefore we only set spindle 1, 2, and 3 with a specific tool in that spindle for both machines.  Spindles 4 + the tool can change as needed on a job.
Does anybody know how to write a report that will print out what tool the CNC program is expecting in each spindle?  That way we could do a set up sheet for the router operator to use to make sure the correct bit is in each spindle before he loads the program and tries to run it.
Our report writing skills are limited, so any help would be greatly appreciated.
