Selective Machining
With Sub Assemblies and Nested Sub assemblies In mind, How do you get machining based on what it is? I have a notch that I like to use on my wood drawer. I use a polyline token in the hardware with the following formula
"=IF(S!ProductCode = "C,2,SA,DF","PLINE",IF(N!ProductCode = "C,2,SA,DF","PLINE",0))"
The purpose of the formula is: I don't want the token active if the lock is on a door, I only want it if it is on a drawer front. It works for the most part but not all of the time.
I need to know how to activate a token based on if it is on a door or drawer front since a cabinet can have both.
Anybody have experience with this?
