Separating FE's machining from Unfinished Sides machining.
We're running Imperial Component Library and I'm trying to separate the machining on my FE's to be doweled and the other Unfinished side to be screws. we have a limited Horizontal dowel machine and I can't bore both edges on my parts because of the spacing. I can't find a global for FE machining, is this something that I would have to program and create?
Thanks in advance.
