Set Position of Associative Dowel Holes on Different Thickness Material
Hi,
I am running into a weird issue where i cant assign the thickess/position of my associative dowel token. I want to add dowels to a fixed shelf thats 1" thick but it will only offset 3/8" from face 5 instead of centering on the material. Is there a workaround for this or was it not meant to work in the way i am looking it to?
