setting for edge banding
Hi there,
We met a issue about the edge banding material set up different with the manufacture dimension.
For example, the panel dimension is 2250*605 and should have the edge at 2250&605, one of each. Normally we use 1mm & 2mm edge material, and our edge banding machine is able to trim 1mm off and glue the 1mm edge on. Therefore, we won't miss 1mm from 2250 side. But not, when we input the dimension as 2250, the output of nesting optimization displayed the cut length &width is 2249*604, as well as all the doors and drawers are missing 1mm of each banded side. We could ask the staff not to trim the 1mm edge from edge bander, but it will waste a lot of time. We would like to know how to set up this configuration from software and achieve the goal of 1mm trimming and 1mm edge on.
