Shadow Line Finger Pull machining location? Machine tokens not showing up in Part Properties Help
Hi,
I am trying to work out how the shadow line finger pull machining gets added to the left and right gables, I know when you go into the shadow line subassembly you can turn off the left or right machining but I cant find anywhere where the machining tokens.
If I press Q (MVPARTPROPERTIES) on the product and then click on the Base Left Gable, or the Base Right Gable and then click on the machining tokens tab should it not come up with a token that controls the machining for the Shadow Line finger pull cutout into the side of the gable? I just don't understand how it is getting added.
I'm trying to add associative machining between two parts within a product, I was looking to see how it works with the finger pull but I just can't see where it is being added.
I hope this makes sense,
Thanks
