Adjustable Shelf Locations Lined Up With Bore Holes
I let my OCD run wild and took some time after hours to correctly locate the shelf supports and shelves. There were a few ways I could have done this and, if there's interest, I could go through the reasons why I wound up doing it this way.
We use Continuous_Shelf_Holes that are Centered and, depending on the product, will as many as seven or eight shelves. Using MV to draw the section details is great, but having to go in and constantly modify them by hand every time can be mind-numbing. I figure that this little modification will save me about 8.3 million hours of clicking.
I added some prompts within the subassembly to figure out the "Actual" Z location based on existing formulas and G!/L! prompt constants.
The attached .cutx file only works if you have the Shelf_Location_Adjust prompt (row 214) turned on.
-Ezra
