Shelf Oversizing
We're working on a floating shelf design where we want to maintain the original dimensions in the drawing. However, we need the actual cuts to be 10mm oversized on each edge, including a 45-degree miter, without reflecting this oversizing in the model. We attempted to use the "Edgeband Thickness" as the parameter at the processing station with negative parameters to achieve the oversizing, . Despite this, after post-processing, the dimensions remain as the original size, and the oversizing adjustment doesn't apply.
Has anyone encountered a similar issue or have any recommendations for solving this?
