Microvellum Knowledge Network
Slab Molding Doors
Does anyone know if it's possible to set up a new slab molding door using 2 different moldings? The moldings wrap around the outside edges of the doors. On the Left and Right Edges, we have a chamfered molding that partially sits on the face of the door and wraps the edges. On the Top and Bottom Edges, we just use a Square Molding that essentially just caps the top and bottom of the door and captures both the door panel and the Chamfered Moldings. I have both moldings set up in the Lookup Table but the way the way the subassembly formulas are set up to look at the Lookup Table, it only draws the one molding the whole way around the door. I've tried to rewrite the Top and Bottom SM Parts formulas to look at the Top and Bottom Molding Name but the Subassembly Prompt that drives the Molding Profile that gets drawn is what looks at the Lookup Table and stops at the first of the 2 moldings listed. I've attached screen shots of both moldings and of the applied molding subassembly, if that helps.
Thank you,
        Google Review
