Curious to know if anyone is using the Extruded Product when creating Die Wall configurations with SM Suite. It seems to be a good solution for any subdeck work seeing that it is programmed to machine the connection points. I believe the SM SUITE is not able to provided the machining for Extruded Product, unless it is in the form of a dado and or dowel connections.
