SMA material selection?
When SMA prompts for a material selection, if I used find and replace inside our typical library materials, it only lists 1 set of the find and replace that I did. I am assuming it is the 1st material names I changed or 1st spec group its using, however I need to select the other materials that I replaced. Now I am forced to create a project specific material, since there is no way to select a spec group after analyzing. Would be nice to just automatically have the parts formula driven to a spec group and then if we need to hard code a material, we can still do that. Otherwise we have multiple materials but they are the same unless we go thru each part and redo the material assigned to them. Is there a way around this or something I'm not thinking of?
