I created a layout of six 2D panels in AutoCAD, and all parts have a grain direction assigned. I imported them into Microvellum, converted them into 3D parts, and then ran the Solid Model Analyzer. I was able to generate the composite drawings correctly, but I had to manually adjust the grain direction on certain parts to make everything work properly in the part properties. Is there a way to globally set the grain direction for all parts so they consistently follow either the part length or width without needing manual changes on individual parts?Could this be cause due to the part being rotated when it was a 2d drawing?
