Solid Modeling Tools - Stud Spacing
In Solid Modeling Tools, when you add a stud(s) at a joint (say, for die wall), all the existing studs remain in their current location. The space between the new stud at the joint and the next (existing) stud will be different from the current stud spacing. It would be nice if Microvellum could automatically recalculate the stud spacing on either side of the joint. Right now, I do not believe there is a way to recalculate the stud spacing between the joint and the end or another joint. The stud spacing is based on the construction path length.
