Has anybody else dove into using solid wood doors in the foundation library.(other than the generic five piece jobs that is)
It seems massively stripped down. No more door libraries, just type and style. Is this meant to be a build your own sort of thing?
All the Cal Door profiles and applied mouldings are in the lookup tables, but i'm a little perplexed for how we're supposed to set a new style for a project. The only solid wood door type the top level list contains out of the box is the Generic Five Piece.
Before adding some tables to behave how the CL door selection worked, i was hoping someone else has tackled this and could share any insights they gained of the intent behind this new system in the FL.
Am i missing something obvious here?
