Solid wood doors
It has been a while since I've had to change the doors to solid wood slab doors. Since there are so many ways to do it in MV, what is the best method? Change the door material pointer to solid wood material or change the door style to something? Looking for standard square edges either way.
Problem: the door has routing on the face but it is full solid wood. I'm assuming the best way to accomplish this if the door routing changes in the future, is just copying the door wizard and applying a specific spec group to the cabinet?  Otherwise as far as I know you have to edit every door's subassembly drop down list or save a seperate subassembly with the machining? We want to limit the amount of those since they dont get updated.  And since product list doesn't have an edit multiple subassemblies option, not sure the best method. 🤔 maybe im over thinking it
