Starter Spreadsheet For Solid Modeling
When you create a new product using Solid Model Analyzer, all the parts go into a blank spreadsheet that has only Height, Width and Depth.  If you are a shop using formula driven materials that require local prompts to get the material information from, these new products do not work correctly.  Can we get the ability to customize the spreadsheet that SMA uses by default for new items?
This opens the door to many possibilities including having default draw tokens at the ready.
Kind of like using Drawing Templates, let us pick which is used when.
