Strip Lighting Insert Should be a global option
Strip lighting insert should be a global option for each cabinet type, and or at the minimum a product prompt in the cabinet itself, having to add the sub assembly for it is a very cumbersome job if have a few units to do, or am i missing something simple here for bulk applying? Thanks
**Edit, the formula for the cutting tool also appears to be wrong by default, it is looking for the global shelf tool.
