Manually inserted subassembly origin placing outside the cabinet
Hi all,
I’ve hit a frustrating issue. When I use the default subassemblies that come with a product, they place correctly. But when I insert a subassembly manually, its origin lands outside the cabinet.
I’ve tried positioning it with formulas, pick points and pick corners, and it always ends up in the same spot. It’s turning what should be a simple cabinet into a very slow job.
Has anyone else run into this, or does anyone know what might be causing it?
Thanks in advance.
