I would like it if changes made to the processing stations from the processing center were not saved outside of the work order without being prompted. Sometimes i like to make tweaks to the processing stations for a specific work order and it would be nice if i didn't need to remember to come back and undo those changes later.
Basically when you hit OK on the changes i would like a popup that says something like, "would you like to commit these changes to the tamplate?" or something like that. Otherwise the change should be contained strickly within the workorder itself.
This is also convenient should someone need to comeback later and remake some parts, They wouldn't need to know/remember the changes that were made to the processing station.
