I have used a callout block in AutoCAD for many years, and when clicked, you can change the callout information and change whether the drawing is a section, plan, elevation, and so on.
When drafting the scale attribute text changes when I change the scale, and when this block is seen through a viewport in AutoCad the scale changes to match the viewport scale. In BricsCad this same block works in all the other ways except the scale matching the viewport. It always prints 1:1 (Paperspace Scale) and I can't figure out how to fix that. Not having to remember to change the scale all the time, it's a nice time saver if it worked properly.
My only workaround I found is that the attribute text can be linked to a viewport in paperspace but you have to link it to every viewport you make, which is more time-consuming than just changing the text manually.
Any suggestions?
