Through cuts
We are trying to get through cuts and can't figure it out. We were using brad point but the edges on the bottom side are not good enough so we got the through point bit from Frost but when we try to set it to      -z.20" it doesn't cut all the way through. Shows in the program that all is good but the gcode only goes to -z.002".  Any suggestions?
Thanks in advance
