HI,
I notice that you have removed: What product are you using? from the Ticket creation.
Shouldn't this still be in the submittal form to assist in troubleshooting or have you found that if it's a problem in AutoCAD it's a problem in Toolbox OEM or visa-versa.
Using:
- AutoCAD 2019 (secondary - Library Designer cherry picking & shop support while working on new jobs...sparingly - don't want to work in same Project database)
- AutoCAD 2020 (primary)
- AutoCAD 2021 (installed & not supported)
Best Regards,
