Toe Kick inset on Face Frame Cabinets
We don't do a lot of face frame cabinets so I am still trying to get familiar with the framed library. I just got caught in a mistake that made it out to the shop. The toe notch did not calculate for the hardwood face frame. The global setting has a set back of 3" but they will finish out at 3 3/4".
I am Using the 50.3 Library. I see that the 50.7 Library is calculating the set back correctly.
Not sure when this was fixed. Just a warning to others to keep an eye out. Sometimes I put too much faith in the software that everything will be correct without double checking everthing.
