Tool File import
So I am new to messing around with tool files. Is it safe to import CCL tool file into Foundation? I was able to import with the TLFX format. However they do not show up in the work order screen. I also had an older foundation cnc tool file we used for testing set as primary for the 2d sheet editing tools but for whatever reason I still had to select it from the dropdown and the one i imported doesn't show up there either. It gave me a router missing error when i tried to update the gcode for the nests. I feel like there is a step I am missing. Where can I find documentation or tutorials on this?
also, how do i turn off the imperial default nest. They aren't selected in the work order but still produced the folders.
Also, I would like the ability to be able to select my own toolfile default instead of it changing for all users. Some of us use SMA and some are working on other things. Maybe there is a way to set this up differently?
