Tool Path Tracking
Something I have been missing for years is a report that has the totals the tools have cut.
I had a software package years ago that would print out a report on how many inches each tool was actually in the cut, and how many inches of index moves it had made on either a per panel or per batch basis.
I found it handy when tracking tool life and the index move report really helps if you are designing a high repetition stock run as you can actually see the index move number go down as you increase the tool path efficiency.
