Updating/modifying Subassembly information to global library through saving by overwriting existing subassemblies
Hi everyone,
We have encountered an issue when we attempt to save a new or overwrite existing subassemblies in our global library. So, we attempt to Save by Overwrite an existing subassembly globally with additional information inside the subassembly. However, when we attempt to revert/update other products in our library which hold/use the same subassembly, the latest version of the subassembly is not selected, Microvellum instead selects the previous version without the additional information added to the subassembly. So we cannot update other products in our library which use the same assembly.
In addition, when we've tried to save the Subassembly under the new name, we've got the error "Application doesn't support Windows Forms just-in-time debugging" (see pic).
Thank you for your help.
Regards,
Roman
