Upgrading from MS SQL Server 2012 to 2022 - having issues...
Hello - we have attempted to move our 2012 Microvellum db to SQL 2022 several times but there is drastic performance hit each time so we end up reverting back to SQL 2012. The new server has more resources allocated to it than the old server so that is not the problem.
I realize that's a lot of SQL versions to jump. The SQL engine and security has changed a lot! I'm wondering if there are config adjustments that need to be completed on the old 2012 MV database to get it to perform better on SQL 2022?
Is there any documentation available for installing microvellum database on SQL 2022?
Any help is appreciated.
Thanks,
Joel
